Bass Guitar Pots..what size?
Started by petemoore, May 04, 2004, 06:06:09 PM
I'm installing pots on an Aria Pro II Bass, where there are none, and wondering what size pots would be good as a minimum value there.
Samuel
If it's passive, maybe start with 250K and possibly move up to 500K? Those are pretty standard I think.
Fret Wire
Usually 250k is used with single coils, 500k is used with humbuckers. The larger values will be more open and brighter sounding (less highs bled off). Tone caps are usually between .050uf and .1uf for bass.
Fret Wire
(Keyser Soze)
