easyvibe problems!
Started by jpb_guitars, May 25, 2004, 04:36:28 PM
jpb_guitars
I've got problems with the easyvibe I built a few months ago.
After a while, the LFO stops working. The led's stop to pulsate and the phasing tone stops.  :(
When I unplugg and plug in the cable the LFO works for about 2 seconds.
Don't know what to do???
Arno van der Heijden
I hate to say it, but.....check your battery...
Not enough gain in the LFO to sustain oscillation. The unplug/replug cycles the power supply and kick-starts the LFO.
Need voltages on all the IC pins. Whose layout are you using? Mine?
jpb_guitars
The effect works for about half an hour. Than it quits its work.
The same problem apears with an 9V-power-supply. I've used the layout
from Willie's homepage.
The problem first apears after putting the circuit into a box.
lightningfingers
very OT, but while we're on the subject of the easyvibe, how hard is it to perf one?
Anyone here done this before?
U N D E F I N E D
jrc4558
took me 2 hours to perf.
