LED pulser
Started by Vincent Volta, May 26, 2004, 08:27:38 AM
Vincent Volta
Hi evryone,
I remember seeing somewhere on the net a schem for a led pulser bypass, what I dont remember is which page was hosting it. The thing is intended to pulse when the pedal is on, rather than a continued blink. If anybody knows, thanx in advance!
May the yoghurt be with you.
maximee
Marcos - Munky
gez
Set up 2 CMOS inverters as a square wave oscillator.  Connect the oscillator's output to another inverter in the chip via a reverse diode and connect a LED and series resistor from V+ to this inverters output.  Voila, a flashing millennium! (input of invert gets grounded when effect is kicked out and so turns off LED).
