brighten tone as volume pot on guitar reduced?
Started by Alpha579, June 03, 2004, 05:33:10 PM
Alpha579
Is it possible, without using an inductor, when series resistance is added to an overdrive circuit when the volume control is turned down, create a low cut filter? you could do it with an inductor like this i think:
resistance from guitar pot
--/\/\/----------------(to rest of circuit)
              &  (inductor)
             grnd
Can you do this without an inductor?
Alex Fiddes
Alpha579
ah, sorry, diagram didnt come out like i expected :oops: . Its just a resistor, then an inductor to ground
Alex Fiddes
cd
You want to add highs when your guitar's volume is turned down?  Have you tried a cap across the volume control - that usually works very well, like a bright switch.
Alpha579
yeh, i might do that to my guitar, but i want to be able to use this pedal wiv lots of guitars without modding them all...
Alex Fiddes
I'm gonna put a small cap across my favorite pickups's volume controls, I'M P.D.Sure I'll like it better that way.
 For the vol control to do this the cap has to be on it as far as I know, otherwise a treble boost could be used to accentuate treble of any 'incoming signal.
cd
Quote from: petemooreI'm gonna put a small cap across my favorite pickups's volume controls, I'M P.D.Sure I'll like it better that way.
Huh?  Just put a cap between the "in" and "out" lugs of your volume pot.  The way it works is at high frequencies, the cap looks like a dead short, so it lets more highs through.
RedHouse
The cap by itself can be kinda schplanky sounding as you turn down the ctrl, going from full tone at full vol, to squawky at half vol.
It is a bit better if you add a series resistor with the cap, a value in the neighborhood of half (or a bit less) of the pot's total resistance works very well. Makes it so the tone stays very nearly the same as the knob is turned down.
For a 250k Vol pot use a 130k resistor, for a 500k vol pot use a 250k resistor, start in this ballpark and adjust to your taste, you might be surprised how linear you can make the tone stay with the volume.
Paul Marossy
I used a 0.001uF cap on the volume pot of two of my guitars, and I have no problems with it.
