Build trouble...:(
Started by Alpha579, July 09, 2004, 12:47:21 AM
Alpha579
Hi all,
Ive just boxed up a wee overdrive i made, and it worked great on breadboard, but now when i turn on the effect, all i get is white noise and hiss. It bypasses fine, and the voltages on the perfboard are correct. Here's the link to the schematic:
http://www.geocities.com/alphaeffects/tikadrive.htm
Any ideas on what ive done wrong?
Thanx,
Alex
Alex Fiddes
zenpeace69
Well, I'm just a noob myself, but I would suggest double checking the transistor and any diodes and make sure they are in place correctly.  Make sure you are well grounded, too. Also check your caps that require pos/neg placement.  Beyond that, I guess you could check some of the troubleshooting hints in the FAQ.
I am noob...
Travis
If there was ever a case for the audio probe, this would be it.  I would suspect a wiring error, (for me) most likely at the switch.  What you've said so far suggests that you have output, but no input.
Alpha579
yeh, i originally thought the input wouldnt be connected, and whatdya know, i messed up on the gain control wiring big time. Ive also spotted a track on the board i need to cut, so ill do that as soon as i can...
Alex Fiddes
talking_goat
I had a similar problem. i had everything wired up and tested it and it worked fine. once i put it into the box though all i got was the bypassed signal, and when the switch was on, a little bit of noise but nothing else.
