dr boogie 2 volumes 2 gains 2 footswitches 2 leds , wiring help?..
Started by deadastronaut, May 15, 2011, 01:35:37 PM
okay so this is what i have...gaussmarkov boogie layout. and ricks switching diagram..(thanks man)
but i just cant work out how to actually wire this to the pcb????..
can anyone join the dots for me please!...i'm sure this will be a lot of help to others too!!!...(or maybe just me.....i'm being a dumbass again!) :-[
i'm confused!!!!!. :icon_redface:
thanks guys!..btw i took the pcb gain pot off the pcb diagram, to reduce my confusion a little.... ::)
i presume i need 1x 3pdt and 1xdpdt to do this?... for on/off and double gain/vol switching...hmmmm....
The gain a volume pots are both wired with one of the outside lugs to ground, the signal goes into the other outer lug and comes out through the wiper.
So you remove the pots, figure out which wire is the one to ground and remove that. The wire that did go to the remaining outer lug goes to "...Pots input" on Rick's diagram, the wire that did go to the wiper goes to "...Pots Output". Attach ground on Rick's diagram to ground on the PCB somewhere.
cheers slacker, like this then?..
still confused about the on/off bypass switching though!..with led....... :-\
arma61
Quote from: deadastronaut on May 15, 2011, 02:34:28 PM
still confused about the on/off switching though!..with led....... :-\
I was confused too at the begining..... I was looking at the 3PDT, as I normally do, switching center/top center/bottom in this case is center/left center/right  :icon_mrgreen:
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
its ok if ya look sideways... :-X
hmmmm.....
arma61
Yes, having cross referenced to gaussmarkov (the things I do for you...) that looks correct. Bear in mind that each set of two pots are in parallel with each other, so it may affect the taper slightly, and will also half the resistance - ie resistors in parallel. It may be sensible to double the pot values for that reason. BTW, I've never tried this arrangement myself, just put it together for a friend who wanted to do it.
cheers rick... ..yeah i shouldve put the links... :icon_redface: ;D
nice one man, so the wiring is ok, cool.
yeah i'll try different pots and see how it goes with values/taper..
so i'm a guinea pig on this then?.... ;D
i'm going to try a full layout/diagram with both switches...just so i can visualise it all....cheers. :icon_wink:
ok i did a very rough layout... to see what it might look like...seems to make a bit more sense to me now....
EDIT:
i'll draw it out much better than this, when ive grasped it... :) is this ok?...
Quote from: deadastronaut on May 15, 2011, 06:50:14 PM
No, it's tried and tested, didn't even pop when switched.  :D
brilliant!...whoohooo....
layout looks ok then? do you think...?...sort of looks ok to me now!..
ive seen others use a dpdt with led on this..(somehow) .???
just designed my box facia...its gonna look the nuts.. took ages to get right....its going to be called '        '  ....you'll have to wait.. :icon_wink:
i'll etch it tonight...then get drilling..
cant wait to get this up n running... \m/  \m/.... :icon_twisted:
as long as my diagram above is ok of course?????....anyone confirm the diagram above ^^^^^^...?
Galego
I think the switch on the right is rotated 90º. Other than that i think it's OK.
ahhh so ricks switch orientaion was right...should 've known eh... :icon_mrgreen:
like this then...:)
edit heres a tidy version.....with gaussmarkovs bypass wiring...i'll put it here in case anyone else wants it... :icon_wink:
