3PDT Passive A/B/Y box with LEDs
Started by coffee-sipper, September 05, 2004, 03:11:09 PM
coffee-sipper
Does anyone know of a schematic or digram of how to wire 2 3PDT switches for an A/B/Y box (w/LEDs)?  I have seen the transformer based A/B/Y box but I would like something that can operate with out power (obviously the LEDs won't work without power but at least the switch will).  Grounding is important but I will not be using the box for running 2 amps, so the transformers are overkill and I want the build as simple as possible.  I can't seem to figure out how to wire the grounds or the LEDs.  Thanks for any help I am starting to get frustrated.
Noisician for hire.
David
Look for audioguy's thread from Friday headed "How do I put together an A/B with a DPDT".  There are a couple of possibilities for an A/B/Y box with LEDs in that thread.  I'll vouch for one of them because I built it when I was too inept to even be a newbie.
Michael Allen
Even if you're not using it with two amps, I'd still go for something with some circuitry to prevent humming. I use a passive 3pdt to switch between the Normal and Bright channels on my Sovtek. I run a distortion on one channel and when I switch channels, the background noise from the distortion is still audible on the clean channel at almost the same volume as on the distortion channel.
Anyways, do a search for Gilles Caron. He did some drawings awhile ago. That's what I used.
Gilles C
Quote from: Michael AllenAnyways, do a search for Gilles Caron. He did some drawings awhile ago. That's what I used.
Glad to know I've been of some help.  :D
That will be my motivation for this week.  :P
That's the part I want to move to my new host this week. I also wanted to correct a few things at the same time.
That's the page: http://members.tripod.com/gillcar/id19.htm (Danger, banners aheads  :evil: )
but as you don't need the "effect loop" option, you may prefer this drawing: http://www.fulltone.com/PdfFiles/ab.pdf
Gilles
wizard
http://www.diystompboxes.com/sboxforum/viewtopic.php?p=162075#162075
I don't have any shematics of my A/B/Y BOX now.
But it's not that diffcult to figure it out.
The A/B switch has a X-wiring for muting unused channel.
The Y switch connects A and B together when activated, it is also used to cut off the muting ground connection when Y is on.
Ground is conected to the sleeve of all phone jacks.
I DIY therefore I am.
aron
I wonder if the one in the FAQ section of this board would work? Amp/Tuner box???
The Tone God
If you want to drive two sources like amp inputs at the same time you should really go for a simple active box.
http://www.geocities.com/thetonegod/aby/aby.html
Schematic, layout, and PCB are in the downloads area. Maybe tack on some isolation transformers like in the GEO's Spyder if you get hum.
Andrew
