Soldering Temperature
Started by Rich G., September 07, 2004, 09:39:18 PM
Rich G.
I recently picked up a soldering station with a temperature control.  What is the recommended practice for using the temp control??
For example, when using 63/37 solder what temperature do you set the iron at?  It melts @ 361 deg F, so do you set it at say 400 or do you crank it to 700 for a quick in/solder/out job.
niftydog
it depends on the thermal mass of the device being soldered. If you're soldering tiny transistors onto very fine tracks, you want it quite low. Somewhere around the melting point is a good start.
If you're soldering a wire to a potentiometer case for example, you want it a bit hotter so that you can keep the heat to a localised area so as not to damage the mechanisim.
It also depends on your technique. Turning it up is not a way to assist your bad technique! Also, some devices will specify the maximum soldering temperature and a time limit in the datasheet.
niftydog
Shrimp down the pants!!!
Mike Burgundy
too hot screws up your iron's tip, too cold and you'll fry components. You set the temperature so you can solder fast (1-2s max) but not too high. I prefer 250-300 C for regular electronics (higher temp for larger leads), 350C for pots and 400C for jacks.
hih
