Rangemaster Q
Started by MartyB, September 14, 2004, 07:32:23 PM
MartyB
Building my second rangemaster.  My first was RG's Austin Treble blaster.  With the present one, I avoided using stock resistors and put a 250k pot where the 68k resistor goes normally. Tweaking the pot I found a resistance of 88k gets me the optimum between blatty and thin.  It also happens to be the loudest result out of this effect.  Can anyone tell me if a correctly-biased germ. in this circuit would generally also give (or be expected to give) the loudest volume??
Read GEO tech of Rangemaster.
 The Rangemaster transistor collector is 'supposed' to be biased at 7/9th's of the PS voltage or 7v with 9v supply.
 Set the pot where it sounds good to your ears, and compare it with the 7/9th's setting, then decide where you want it...or use a surface mount pot so you can tweak it at will. Ge's have a tendancy to bias drift much more than Si's.
MartyB
Fret Wire
If it sounds good at a different bias than the 7v, by all means keep it, like Pete said. When you ears and your DMM disagree, go with your ears.
Fret Wire
(Keyser Soze)
