Anyone know where I can find one of these?
Started by mojotron, January 10, 2005, 01:47:16 AM
mojotron
I thought this would be a good topic as I'm looking for stuff..
Does anyone know where to find little rubber feet that you can put a screw through - like the feet on fulltone stuff or like a tubeworks amp?
Also, does anyone make a steel enclosure that is like 2" on the back side, has an incline on the top that you could put a foot switch on and the front is about 1 -1/2" on the front?
I'm wondering if we could all get together and get a great deal on a steel enclosure from a supplier?
Khas Evets
LMB/Heeger makes one. I've used the 2x3x4 enclosure and been happy with it.
http://www.lmbheeger.com/products.asp?catid=28
Paul Perry (Frostwave)
Those little rubber feet that you put a screw thru are pretty common here in Australia, most hardware shops have them.
Unless you want to do something else with the screw at teh same time, I find self-adhesive rubber feet easier (BUT, one key advantage of screw-ons, if the box sits unevenly you can pop a washer under one! easier than sanding down a stickon :x )
