How to convert mxr 45 clone into univibe??
Started by gorgui, January 07, 2005, 07:30:08 PM
gorgui
Hi!
Anyones know the way to convert the mxr 45 phaser clone to univibe??I used the layout from tonepad,and i want to conect a switch to the capacitors,to make it posible...But i dont know what caps to change,any help????
Saludos desde Uruguay.-
Fret Wire
Fret Wire
(Keyser Soze)
bwanasonic
It's a wonderful mod by the way. Try the speed indicating LED as well!
Kerry M
gorgui
Thanks for the reply....but im a newie.....its just ome switch or I need two switches????Thanks again for your help!!!!
Paul Perry (Frostwave)
gorgui, that is one switch, it is a "two pole two position" switch, it can either be a toggle switch or else a normal stomp switch like for a bypass.
The dotted lines between teh seitches means "these switches are mechanically linked inside the switch casing".
gorgui
Paul,Fret wire & bwanasonic:
                                         Thanks so much for your help,i will try the mods...I hope to switch the right ones caps,I will keep in touch to tell you about it....Thank you again,guys!!!!!!!!!
