3 Legged Dog 1 Meg pot substitution?
Started by javacody, January 09, 2005, 10:06:33 PM
javacody
The biggest I have is 250K, will this lower the amount of gain available? What if I run 750K Ohm of resistance in series with it?
vdm
250k will indeed decrease the available gain in the pedal. I would suggest if you really want to get it working *now* then use the 250k while you get yourself a 1M pot.
By putting 750k in series with the pot you are going to make the gain control effectively turn from 75% to 100% of the normal pot travel.
Start with just the 250k and if you *need* to have higher gain now then put some resistance in series. At least the lower gain will give you a taste for the pedal and what tones to expect.
and remember a fresh battery is essential to get this thing to work without squealing.
Good luck, and get a 1M pot  :D
Trent
javacody
Actually, I think you have it switched around as I decided to use a 1 Meg resistor where the pot would usually go, and had a very weak signal. After I removed the resistor, the gain jumped way up. I may give a 250K pot a try, as I'm not real interested in low gain situations with this pedal.  LOL  ;)
Thanks for the help though.
