The RAT
Started by Fp-www.Tonepad.com, January 08, 2005, 05:00:43 PM
amonte
Hmm...come to think of it, I think I saw 4 diodes in mine to...
is it still worth modding to the Vintage Rat specs?
Prive
One Fet is the buffer stage ant the other is the led switcher i think.
I see this in a turbo rat.
Saludos, Marcelo.
Fuzz boxes don't need on/off switch!!!!!!!!
Boofhead
QuoteThat schem doesn't seem to correspond with what's in my Rat 2.
That's the problem with posting links.  The original page Francisco posted,
http://www.happybob.com/rstrand/rat/rat_versions.htm
says the Rat 2 version on that schematic isn't right.  The other Rat 2 version on that page does have the diodes - my previous post tries to cork-up the holes in that one.
bwanasonic
I started a separate thread with the photos I took of the Rat 2 in case anyone is interested and missed it:
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=28770
I like my Rat2 for what it is, so it's in that elite group of pedals I own that hasn't been mucked with in some way. But now I'm starting to get curious about "The Rat Variations", so maybe I'll have to put the Rat on my "DIY To Do list".
Kerry M
jimbob
Great pics!! Thanks! Was that a lm308n?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
j0shua
jIMBOB :
THE LM308 IS A DUAL OPAMP, YOU CAN REPLACE WITH THE 4558 WORK SAME  :D
j0shua
ARE A GOOD MOD FROM THE ORIGINAL CALLED RODENT , I BUILD THAT AND SOUNDS EXELENT ......ARE FROM GENERALGUITARGADGETS.COM
ENJOY
           ALSO MANY OF YOU KNOW'S BIG DADDY FROM RUNOFGROOVE PAGE  TRY TO ADD DIODES ON ASYMETRICAL CLIPPING ON PIN OUT #5
ALSO IF YOU BUILD HOWIES METAL SIMPLEX CHANGE THE TRANSISTORS  TO 2N5089 AND YOU HAVE A METAL MONSTER  :)
Paul Marossy
QuoteTHE LM308 IS A DUAL OPAMP
Uh, actually it's not. It's a single opamp, externally compensated...
