diode-compression opamp (updated)
Started by Joe Davisson, January 29, 2005, 01:21:52 AM
Joe Davisson
http://www.diystompboxes.com/analogalchemy/pedals/diodeopamp.html
Also added a better circuit description to the Easy Drive and changed the description of the 5-part opamp to "opamp-workalike" as to avoid confusion with traditional opamps.
The parts count with the new discrete opamp is high, 10 parts per opamp. So use the discrete opamps in audio gain/distortion stages, but regular IC opamps in tone controls, etc. Maybe I'll whip up some small modules sometime. The question is, to SIP or DIP?
Shocktave is too Cool... 8) . I love that sound !!
 GREAT Site !!!
aron
DIP is what I was thinking.
AWESOME! I am going to try it Joe.
THANKS!!!!!!!!!!!!!!!
Aron
Ghandi
No need for selected PNP transistors with the Diode-Compression Opamp, right?
StephenGiles
......and I've just had a delivery of opamp samples! Thanks Joe.
Stephen
Phorhas
Electron Pusher
bwanasonic
I'd be interested in hearing an A/B with this circuit and an IC in something like a Tube Reamer. I would imagine it would *feel* different as well.
Kerry M
ragtime8922
This is great. Before I started building JD stuff every distortion/OD unit i've built had an IC except the fuzz stuff of course. Then I fell in love with working with discretes as it gave more of a sense of fine tuned control. Now with the discrete opamp stuff the possibilities are endless. Great stuff Joe!
RLBJR65
Awsome site Joe! I was just checking it out before loging on here. The Electronic Math Helpers are a great addition as well :D
Richard Boop
Joe Davisson
Resolved a gating problem (a trivial fix, luckily), and the schematic now shows dual-supply rails. I also added a "deluxe" version of the circuit. Both seem to behave pretty well now, hopefully this will do it.
More testing was done, both circuits can operate over a decent voltage range, between about 6 - 18 volts. I tested TS9-style circuits with both circuits, and a Shredmaster distortion section with the basic version. Pretty
decent overall.
I guess the downside is the parts count, but the flexibility is kinda neat. (All-germanum opamp, anyone?) Yep, the diode can be Ge too :) Some things can't come on a chip...
Joe Davisson
Circuit is ok, had to add a 10k resistor on the negative input to prevent the diode from turning off. I briefly yanked the page, but it's back now. Might need to reload images.
-Joe
