Whack Germ trannie idea
Started by Karmasound, February 14, 2005, 10:25:27 AM
Karmasound
Ok this might be silly but....
since germ trannies sound better when they are warm.
how bout the TRANNIE HEATER! :shock:
What is the optimal temp for germ transistors?
I thought of these old battery heated socks I used to have. Then I thought, maybe I can put a tiny little heater on the transistors to keep the temp stable. Or to warm them up to optimal temp :lol:  :oops:
GreenEye
hmm.  Heat tape?
Peter Snowberg
They don't necessarily sound any better when warm, but the gain is HIGHLY affected by heat. Just put a Ge transistor in an hFE meter and watch the numbers move as you hold the transistor body with your fingers.
One way to get a really good sounding fuzzface is to match the transistors at the temperature the unit will be used. The only problem is that the unit will be used over a wide range of temperatures. The hall will be cold when you arrive and if there's an audience, by encore time the temp may have risen by 10-20 degrees (F) thanks to body heat.
You just can't win with Ge..... the material is in ultimate control, not the human.
I designed a "Peltier Fuzz" that uses a thermoelectric cell to keep the transistor temps stable to within one degree..... No batteries for that design! :shock: :D
Eschew paradigm obfuscation
puretube
great idea, Peter!
8)
even cheaper than batteries on the long run...
Karmasound
Quote from: Peter SnowbergThey don't necessarily sound any better when warm, but the gain is HIGHLY affected by heat. Just put a Ge transistor in an hFE meter and watch the numbers move as you hold the transistor body with your fingers.
So how did that work out? 8)
Peter Snowberg
Designed, but never built. :D
It uses a thermistor with an LM339 wired as a window comparitor to drive a H-bridge that powers the peltier junction.
The LM339 outputs a signal to heat when the thermistor gets too cold, or to cool if it gets too hot. Without a window of no action between heat and cool, it would sit there oscillating all day so we give it a few degrees to be OK with what's happening.
The H-bridge could simply be four MOSFETS, but there are some integrated bridges in SIL packages that are much easier to work with.
Peltiers are fairly power hungry.... I got one to play around with and it takes 75W @ 12V which is 6.25 amps! :shock: And how badly does that click in comparison to a 1mA LFO? :o :P ....in a distortion circuit too....  :lol:
puretube
Paul Perry (Frostwave)
Does the Ge gain increase with temperature?
I know the LEAKAGE does! :wink:
