Pots and amature questions
Started by cannikin, February 27, 2005, 05:16:26 PM
cannikin
Hello everyone, I've been cruising the forum for a couple of weeks, and I just started building a tremolo pedal.  I have a couple of 50K audio pots but the schematic calls for 25K.  Will using a 50K pot work without any issues? Or do I have to make some modifications?
Also, if you don't know the value, what is the best way to test Caps - to find the value.   Is it using a digital Multi-meter?  I have one of those assorted Film Cap boxes, but since they aren't Electrolytics I have no idea what the values are.
Thanks.
Theres' audio taper and Linear taper [see GEO secret life of pots]
 50k might do well, tag on a 47k resistor across the 50k pot to make a 25k workalike [outside lugs or potlugs 1 and 3].
 As far as caps, I think the cap value checking devices are expensive.
 If they have no code, I just stick 'em in a FF input cap socket and compare sound to known value cap[s...between the code and just listening I can usually figure out what value the cap is, or there abouts.
KORGULL
QuoteAlso, if you don't know the value, what is the best way to test Caps - to find the value. Is it using a digital Multi-meter? I have one of those assorted Film Cap boxes, but since they aren't Electrolytics I have no idea what the values are.
My $40 Radio Shack multi-meter can measure capacitance from 0.5nF up to 40uF - it seems pretty accurate too.
If your caps are marked, it is a simple matter to interpret them and you'll be in business.
If say, 223 is printed on it:
2 is the first number of the value, 2 is the second number of the value, and 3 is the number of zeros (or the multiplier - 0=1, 1=10, 2=100, 3=1000)
So you have 22 times 1000 or just take 22 and add three zeros to it.
The answer is in pico-farads - 22000pF
To convert it to micro-farads divide by 1,000,000 - .022uF
If you see a letter it is the tolerance rating.
The voltage rating is probably on the cap too.
timwalsh
Hey here is a site with the full explanation.
http://xtronics.com/kits/ccode.htm
I have the same $40 multimeter from radio shack...bought it because of the capacitance function (cheapest one I could find)  Its good to check them, some of them are pretty high tolerance and can drift pretty far from the nominal value
Yeah, well, you know, thats just like your opinion, man
Fret Wire
Here's a $30 beauty:
http://www.electronickits.com/gold/capacitancemeter.htm
Great for double checking values, as well as sorting out odd caps n' such. I have one and find it real usefull.
Fret Wire
(Keyser Soze)
