good place to get boards printed???
Started by doug deeper, March 16, 2005, 08:33:31 PM
doug deeper
can anyone recomend a good place to get boards printed (cheapish...smallish boards?)?
thanks in advance,
doug
Peter Snowberg
what size, how many, double sided, plated throughs, solder mask, silkscreen?
Lots of parameters to see who's best.
I ONLY use fabrication houses that recycle their etchant and dispose of all waste properly. I won't use cheap board houses in Asia or Eastern Europe for this reason.
With most places there is a break at some quantity and PCB making is much about setup costs. For all my small run projects I've been using ExpressPCB amd the results have been wonderful every time. They have a quantity break at 50 boards so use that for figuring short runs if you can. For prototypes they do a 3.8 x 2.5 inch double sided board with plated throughs. You get three boards for $59 (outside California, or $63 in California).  8)
Eschew paradigm obfuscation
doug deeper
basic as possable....2in square....single sided...non through hole. no mask...no screen....
just simple....i need about 50 to start...then more in a couple months...but dont have the time,space,or nerves to print them my self...
mabey one of you guys would be down for the project?
