RunoffGroove: setting voltages on transistors
Started by Yazoo, April 05, 2005, 03:17:09 PM
Yazoo
I've built the Runoffgroove Uno pedal. There is a set of guide voltages for the 4 J201 transistors. Which point on the circuit board should I use to check these voltages from?
Clipped
Check in the middle of the UNO page right above the perf layout. It has the voltages in a little table.
Good luck,
Ron
To Each His Tone.
B Tremblay
Using a voltmeter, place the red probe at the drain of the FET and touch the black probe to the ground rail.  Adjust the appropriate trimpot accordingly.
B Tremblay
runoffgroove.com
dpresley58
I bet you have to post that so often you have a macro assigned on the keyboard.
No offense, Yazoo... I only say that because I had to ask not long ago, too. :wink:
Happy building.
Little time to do it right. Always time to do it over.
MrChameleon
