Heavy distortion projects?!
Started by HeaD, April 04, 2005, 01:16:26 PM
HeaD
Hi, I'm looking for a heavy distortion for PunkRock sound, like boss ds-2 , or marshall jh-1, but more simple to make :P
Can anyone suggest me some projects?
Sorry for my english :|
David
Quote from: HeaDHi, I'm looking for a heavy distortion for PunkRock sound, like boss ds-2 , or marshall jh-1, but more simple to make :P
Well...  ahem...  you COULD do a search for "Smash Drive"...
HeaD
Quote from: David
Thanks a lot David :)
Is this ok?
http://www.generalguitargadgets.com/diagrams/smashdrive_lo.gif
Anyone know where i can download a sound sample of Smash Drive?
Other projects?!  :D
Looks like it...
 First I look at speaker/cab, then amp when building a system...these two left as 'unknowns' leaves plenty of room for 'general' suggestions, these may or may not be exactly what you want...or
 So ... Diode Clipper to ground for hard clipping and drive that with a booster...
 Mini Booster Driving Liquid Drive
 Fetzer Driving Dist+
 DS-1...my Clone has a DCOA [discrete opamp compression al'a J. Davisson]
 I'd suggest maybe releasing a bit more 'pre-existing' rig info, then choosing a project that's predicted to get you at least close to the 'pocket' and leave room for mods 'n such...
  There's a thousand+ Fuzz projects to consider...something with Jfet's maybe ?//
Hal
obsidian.
Never built it myselff, but I plan on..the sound clips sound good :-D
HeaD
Quote from: Halobsidian.
Yeah, it sounds really good! Thank you
Other Ideas?
HeaD
j0shua
HMMMM
Heavy Metal from www.fatboyeffects.com
very agressive Distortion plus many knobs control
j0shua
HeaD
Quote from: j0shuasorry this is the site
http://mysite.verizon.net/res0o2zg/index.html
cheers!
Thanks, i see there is also an heavy metal pedal lite that sounds good!
c'mon, other ideas?!  :D
HeaD
I've modified the Smash Drive layout from GGG to add the Volume control... is this correct?
http://img204.exs.cx/img204/4259/smashdrivelo4tc.gif
I've look at this schematics..
http://www.diystompboxes.com/pedals/schems/smashdrive.gif
Ge_Whiz
j0shua
WGTP
While checking out the Obsidian, check out the BlackFire.  Another great sounding Heavy Duty pedal from Joe Davidson.  I also really like the Vulcan.   8)
Doug Hammonds Sweet 16 is a Jfet Mu-Amp based monster with a big notch filter built in.   :twisted:
Stomping Out Sparks & Flames
NaBo
Quote from: HeaDI've modified the Smash Drive layout from GGG to add the Volume control... is this correct?
Not quite... you want this:
Lug 2 of treble pot -> 500k resistor -> lug 3 of volume pot
Lug 2 of volume pot -> bottom right lug of 3PDT
Middle lug in rightmost column of 3PDT goes to output jack tip
Lug 1 of volume pot goes to ground
Hope that helps... If you need a diagram, just lemme know, but try to get it yourself first  :wink:
HeaD
Quote from: NaBo
Oops! Thanks! :D
