What's a D taper potentiometer?
Started by jrc4558, April 10, 2005, 12:52:54 PM
jrc4558
The Tone God
D taper pots are usually very similar to log pots but with a slighty more aggressive slope. I don't think you would notice the difference with most audio applications so you can use them in place of standard A or log taper pots.
Andrew
jrc4558
I've tried to measure it with a DMM, and it looks pretty weird. The clockwise rotation (measuring so that there's 0ohm in the counterclockwise extreme) has next to no effect on the resistance up until the last quarter of travel.  Isn't that a reverse log?
marking on the pot is D1Mohm
zachary vex
digital taper.  goes up in steps, total of 256 steps per rotation.
kidding.  8^)
Khas Evets
What you described is a normal log pot. A reverse log pot would have a rapid increase early in the travel.
jrc4558
Ok.  Me - moron, you guys are right. *shy:)
