What kind of pots do YOU use??
Started by ESPguitar, April 10, 2005, 03:50:40 PM
ESPguitar
onboard
Alpha, but the first person I talked shop with about parts immediately mentioned CTS.
Do 24mm hold up better than mini's?
-Ryan
"Bound to cover just a little more ground..."
ESPguitar
I'm not sure if they are better, but i have bad memories with mini pots..
RB
phillip
16mm Alpha minipots.  Never had any problems with them at all.
Phillip
H.Manback
Piher, don't know the series but they are plastic. According to the guy at my electronics store the metal ones start to get scratchy sooner.
Don't know if that is true but I like not having to cut the damn metal to shorten the axis.
Oh and they are 6mm, shaft that is
onboard
Quote from: ESPguitarI'm not sure if they are better, but i have bad memories with mini pots..
RB
Why? I've fried a couple in the past when my soldering skills were, um, much worse than they are now. :roll:
Guess I was wondering about the pot life, but yeah, holding up to soldering is  something else to think about.
I read a builder (forget who) who only uses full size pots, implying 16mm's weren't up to par. That's why I asked. I like minis myself.
-Ryan
ESPguitar
I didn't fry them, they didn't work at all.. They costed about 5USD..
They were 11mm wide:) and 6-7 mm beyond the panel..
So pretty small:)
RB
Pedal love
I use omeg 16mm and alpha 24mm, 90% of the time.pl
