Rangemaster colors the sound.. R.G.?
Started by ESPguitar, April 10, 2005, 02:04:00 PM
ESPguitar
That means the bass frequences..
And why is it a 0,005uf or 0,05uf cap on the output? (why exactly yhat value) if i change that cap to over 10uf what happends?
RB
hairyandy
I would think that changing the .005uf to a 10uf on the output wouldn't change the tone a whole lot.  I haven't tried that drastic of a change, but I have put the .005uf and a .01 on a switch and it didn't do much for me.  Changing the input cap makes much more difference I think...
Andy Harrison
It's all about signal flow...
Hairyandy's Layout Gallery
mlabbee
It's supposed to - it's a treble booster.
Unless I'm mistaken, the output cap is just a coupling cap - the value is big enough not to affect the sound.  Going bigger should have no effect - going smaller will start to cut into the bass response.  There's a failry extensive article on how the circuit works, but I can't recall what site it's on - anyone?
hairyandy
R.G. has pretty much written the book on the Rangemaster at the GEOFEX site.  Here's the link:
http://www.geofex.com/Article_Folders/Rangemaster/atboost.pdf
Andy Harrison
ESPguitar
I've read the article..
And why you  put a cap before the output is beacaus we don't wan't DC in our signal..
I'll read that article one more tonight:)
RB
ESPguitar
I can't find anything in his article about the cap values..
Shouldn't the bass frequences pass pretty untouched ?
RB
d95err
Quote from: ESPguitar
RB
No, a treble booster is basically a high-pass filter and a volume increase. It reduces bass rather than boost the treble. In addition, the germanium transistor adds a some nice germanium distortion.
You can add a switch to select different input capacitors. If you put in a fairly large capacitor, you get more of a flat response. However, this doesn't sound particularly good on the Rangemaster IMHO (tried it).
H.Manback
Especially the bass frequencies are stopped.
I don't want to sound rude, because I don't mean it rude, but it might be a good idea to study some basic electronics. If you do not know that capacitors have a impedance of the form 1 / 2*pi*f*C (f is frequency and C is capacitance), you shouldn't be surprised that you don't understand why bass is blocked and treble is boosted.
In short, larger cap -> more bass because the impedance at the low frequencies reduces. Impedance you should see sort of like resistance at some kind of frequency.
ESPguitar
Quote from: H.ManbackEspecially the bass frequencies are stopped.
I understand you:)
That was the answer i needed confirmed, thanks..
