help me with my power supply
Started by BJoe9, April 16, 2005, 01:29:47 PM
BJoe9
hello guys, i used this schematic to build a 9VDC power supply, I breadboarded all the components for this and all the reference measurements are correct. The problem is when I tried to run my TS-9 pedal   off this 9 volt supply, it didn't work. Now, my TS-9 doesn't work using a regular 9 volt wall adapter, but it still works using a 9v battery.
Is my power supply putting out too much current or is my voltage too high to run a TS-9. The DC measurement for the supply was 9.60 volts DC. The only components that I change from the schematiics was the 1N4002 diodes, I used 1N4007 instead, do you think that could be the problem. PLEASE HELP ME! Thanks
