Loop box, hammond eddy 1590B
Started by ESPguitar, April 29, 2005, 11:11:23 AM
ESPguitar
ESPguitar
I thought i didn't need to have grounding wire from jack to jack since the jacks have good contact with the aluminium.. Any other opinions?
Thanks..
putrefusion
is this the "3PDT looper box" that you throw your pedal chain into to turn it on and off
which would mean its the 3PDT looper box that you build boss pedals into to give them "true" bypass?
I'm Elmore James, bitch!
ESPguitar
It's a true bypass looper.. I just used a Alpha DPDT switch, beacause i didn't need to have a led in the box..
Hope this helps..
RB
object88
Doesn't get much more straight-forward than that, does it?
nosamiam
ESPguitar,
Do you happen to have a layout/schemo for that power supply in your album? I've been wanting to build one and something like that would fit on my pedalboard really nicely.  Pretty please?
ESPguitar
Quote from: nosamiamESPguitar,
I used keens power supply schem
This is the schem,
http://www.geofex.com/FX_images/pedschm.gif
And this is the article
http://www.geofex.com/Article_Folders/pedalbdpwr/pedalbd.htm
But! i used ferrites at the end of the dc lines, and it's one tranny regulated to 18 volt and one tranny regulated to 9 volt. At 400Mah, and 230 Mah or something so i had to insert raychem polyswitches to prevent overload on the trannys, they also prevent shortening..
So a dose of improvisation is good to have:P
Hope this helps,
RB
