Drilling a Dunlop wah housing
Started by powerplayj, May 13, 2005, 09:43:22 PM
powerplayj
Can I do it with a cordless drill and regular bit within some limits of reasonable safety?  I want to put in a LED and  external pot.
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
dosmun
It should be no problem.  I added a DC jack on the side of a Dunlop case.
dadude
This stuff is just as soft as the aluminum boxes. Just hold on tight and when you go up to those big bits you'll know why you need to get a drill press!  :lol:
The Tone God
Assuming your bits are in good shape and your drill is powerful enough you should be fine. Use lots of lube and put some tape around the area you are drilling to help reduce the possiblity of cracking the powder coat.
Andrew
