lm386 lm741
Started by benfox, May 15, 2005, 06:38:00 AM
benfox
hi folks !
lm741 is an equivalent of the lm386 ???
thanx in advance
vive les grenouilles :roll:
Sorry for my bad english !!
B Tremblay
B Tremblay
runoffgroove.com
Steben
Do not use 741 chips any more. Even a half of a 4558 is far more better.
soggybag
If the 741 is bad what would be a better quality replacement?
There are plenty of dual op-amps and from what I understand they all share the same pin out. I don't think this is true for single op-amps?
Connoisseur of Distortion
the 386 and 741 are both singke opamps, but they have different pinouts. The 386 has a pair of Gain pins ( 1 and 8 ), and i *believe* that the 741 has nothing at all on 1 and 8.
The Tone God
The 386 is a power opamp meant to drive speaker loads. The 741 is just plain old opamp. One cannot/should not be used for the other.
I wouldn't say not to use 741s as they are not horrible and do have their charm but you would probably be happier with something more modern. If you still have a hang up with using a single opamp, maybe for PCB layout reasons, you can go with a number of different single opamps like say a TL071 which I belive has the same pinouts otherwise go with standard opamps and make life easier.
Andrew
Judgeing from the specs and the sound, just about any other opamp 'outdoes' the 741.
 Reports are the DIST+'s tone is dependant on having the 'low-er fi inconsistancies' of the 741 to be like 'original'. And I have an 'original clone' Dist+ in a box, that I really don't use because...Liquid Drive 'outdoes' it...less noise, higher output, different sound that 'I prefer.
