Cool builds please!!!
Started by kristoffereide, April 25, 2009, 05:57:11 PM
kristoffereide
I've got like a million part, and with me having to wait for even more parts I want to build something to ease the anger over the insanely slow Norwegian customs and postal service.
Can you please post something for me to build? It has to use "common" parts, and not be to critical of parts-selection. (what I mean is that it will still work if I use a different res or cap etc)
I have some op-amps/IC's, and I would like to build something using them. However it is required.
Please help me! My hobby-room is getting dusty!
Quote from: biggy boy on April 12, 2009, 06:22:33 PM
I find it funny how I can have close to 1000 components, yet I never seem to have enough parts to make a project. :icon_eek:
bluesdevil
Browse the layout gallery here or check out the usual project sites like Tonepad or General Guitar Gadgets to start.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
sean k
Circuit snippets by Tim Escobedo
http://www.geocities.com/tpe123/folkurban/fuzz/snippets.html
always simple to make and amazingly educational and surprisingly useful.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
CLAAS
---the 1. of April---
is Dust in the Wind for this Jear...
...or is it for 2010????
The French connection
ICs/Op-amp and easy...Dist+/tune reamer/ruby amp...Search around with your IC number (ex. 4558, lm741)
Check http://runoffgroove.com/articles.html.
Enjoy!
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Paul Marossy
If you have an LM386, the Smash Drive is a fun one to play around with.
The Tone God
Define "cool". I considering anything I build that works to be cool. It tends to be not very cool around my place. :icon_redface:
Andrew
oldrocker
The runoffgrooves.com has the new Mockman 2.0 version up.  If you have a dual opamp this circuit rocks.  I breadboarded this just because I had the parts for it.  After trying it I was very pleased.  So much so I perfboarded it a put it the same enclosure as the first version I built.  It doesn't sound like the first version at all.  It sounds fantastic.    :icon_biggrin:
oldrocker
oldrocker
kristoffereide
thanks! Runofgroove has everything I'll need for times like these :D
sean k
Quote from: The Tone God on April 25, 2009, 09:34:35 PM
Andrew
My hit rate must be about 15 to 20% so I entirely agree with you. Honestly maybe quite a bit less. :icon_redface: 2
My idea of cool is a schematic that takes me ages to design into PCB tracks. After drilling, soldering and mounting in a box... if it don't work I'm over it. Onto the next thing.
CynicalMan
Quote from: sean k on April 25, 2009, 07:38:59 PM
+1
A lot of these circuits are very innovative, simple, and fun to play around with. They're also often funny (check out the bronx cheer ;D).
kristoffereide
Thanks again! I'll be building at least one tonight! All the builds on both sites look really cool, and looks like fun builds. I'll give the ruby or little gem a go :D I've got some plexiglass laying around that i'll use as casing. I think i'll try a couple of car-speakers to these builds. Hope I get it right!
