Screaming Muff
Started by Radamus, August 19, 2008, 07:21:37 PM
Radamus
I recently completed a Meatball clone and I've been having a lot of fun with that, but I thought I'd try working the big muff (triangle, I think) into the effects loop. The result is quite a bit of a volume drop, and there is a high pitched tone that comes through rather strongly. I took the audio probe to the muff (which makes the sound whenever the 3pdt is set to on, even when only plugged into itself) and I got the shrieking sound everywhere. Not much of a place to start. The muff has no IC's in it, so nothing's oscillating to my knowledge. Any reason why it would scream?
  • It only screams when not in bypass
  • It had worked just fine earlier on its own, now it doesn't
  • No IC's
  • I don't know where to start
Usually, I would use the audio probe to find the place that is having a problem. Unfortunately, it whistles everywhere.
Any help would be great. Thanks.
Go read "What to do when it doesn't work".
Barcode80
and FYI, IC's being in the circuit has no bearing on whether you get oscillation or not. oscillation amounts to a signal constantly overlapping itself, which will happen any time you attach an output back to the input.
Radamus
I thought about it a bit more and I think that I forgot to ground the send/receive jacks. I don't know why I thought switching jacks were any different.
