Can a regular pot be used in place of a trim pot ?
Started by Pine, June 29, 2005, 02:32:17 PM
Pine
In a schematic that calls for a 500K trimpot, will a regular 500K pot work the same?
gez
Depends on the circuit, what the trimpot is doing etc.  In many cases the trims are there for bias so there's not a wide range of tuning you can do before you bugger up things.  replacing a trimpot with a pot and stop resistors might be the better way to go.  Again, all depends on the circuit.
MartyMart
Yes of course :D .......but it wont fit "inside" the enclosure  :cry:
Its only worth doing this for :
A - testing/breadboarding
B -  if its a function that you "want" to have control of outside the box
If its for "bias" or something similar that you wont want "moving about"
then dont do it  !
Cheers,
Marty.
Pine
I want to use it for a gain knob on the "Boutique boost" schematic found at general guitar gadgets at http://www.generalguitargadgets.com/diagrams/joam_lo_sm_b.gif
MartyMart
Quote from: PineI want to use it for a gain knob on the "Boutique boost" schematic found at general guitar gadgets at http://www.generalguitargadgets.com/diagrams/joam_lo_sm_b.gif
Do you mean "R7" - the 500k pot ?  .. I dont see any small "trim pots" on
the schematic, so yes all three of the pots at the top of the schem are
meant to be "real pots" outside the enclosure ( box )  :D
I tend to use 16mm "Alpha" popts for all my builds, you can get all those
values from various places, www.smallbearelec.com   for instance .
Cheers,
Marty.
Mike Swan
Pine, is this the schematic:
http://www.generalguitargadgets.com/diagrams/joam_sc_b.gif
You can use a regular pot for the gain pot, but I don't think it's worth it. Just use your guitar's volume knob to adjust the "input gain" to the effect.
formerMember1
martymart:
i got a 10k trim pot 16mm "Alpha"  and 100k of the same. why does mine have like ten notches in it when you turn it? like it doesn't rotate like a normal pot on a guitar. it stops at certain points.   :?:
i am using them to bias a transistor. can i still use the 10k pot for the volume control after i am done using it to bias?
thanks :D
ps:i am using it in a dallas rangemaster clone.
also, do you know where to put two pulldown resistors(2.2M) so it doesn't pop when the effect is bypassed. i am building it on a terminal strip according to geo fx. actually it is the austin treble blaster.
sorry for the off topic :roll:
Hal
Quote from: formerMember1martymart:
you bought a pot with "detents."  Don't buy these, they are annoying
PINE:
did you mean to say "can I use a trim pot instead of a normal pot?"??
Pine
Quote from: Hal
PINE:
No, the parts list calls for a trimpot, to be mounted externally
gez
Quote from: Pinethe parts list calls for a trimpot, to be mounted externally
Hint: it helps if you tell us what the project/schematic is and link to it...
 Yes...I think so...you can temprorarily place a pot as a bias resistor, set the bias using the pot, remove the pot without readjusting it, measure it and replace with fixed resistor for permanent bias set. Use the pot for something else.
 For setting resistance I sometimes use pot + resistor. For instance I want to be able to adjust between 33k and 68k...a 33k stop resistor and a 50k pot allows adjustments between 33k and 83k [no need for running out and getting a 100k pot, also the adjustment tuning is finer.
 FF's I like to use a 10k and 4k7 stop resistor. This makes fine tuning the actual values easier than using a 20k...
 Apples/Oranges/One Odd/Three of the other...
Pine
Quote from: gez
Sorry; http://www.generalguitargadgets.com/index.php?option=content&task=view&id=93&Itemid=121
It is the project called "Boutique Boost" on this page
MartyMart
Quote from: Pine
Quote from: gez
Pine - sorry, OK we get it now  !! :D
Thats your "input gain" trim pot and YES you can use a regular pot just
like the other two in the schematic/parts list .
However, your "guitar" volume pot is an "input" pot to the circuit .... !
So you could just use say a 470k resistor direct from the input jack
socket tip to the top of the 1M reistor which goes to ground and not
bother with that 500k pot, control volume with your gtr vol control :D
Make sense ?
Cheers,
Marty.
Pine
Quote from: MartyMart
Quote from: Pine
Quote from: gez
Make sense ?
Cheers,
Marty.
Marty, do you mean attach it to the top of the resistor labelled R1 in the layout?
It can be nice to have the 'second guitar volume control' on your box's input, for setting Max gain at a level less wooly sounding...for matching pickups output levels to the input of the box, the Guitvol does the same thing, but trying to stop at an exact 8.5 guitar volume setting while playing can be 'inaccurate' or hard to do, having the pregain setter on the input makes your choice of Max gain available at full CW guitar volume.
MartyMart
Quote from: Pine
Yes, so input jack to board --> 470k --> top of 1M  ( R1 ) --> etc
As Pete said though, an input volume pot can be handy !!
Cheers,
Marty.
gez
Make life easy, replace the 500k with a pot and ditch the 1M resistor (R1); it's superfluous, the pot is acting as a pulldown for biasing the FET.
