passive ring modulator
Started by guitarhacknoise, May 15, 2004, 03:19:26 PM
guitarhacknoise
[quote="Paul Perry (Frostwave)"
A warning sign: when the bleedthru changes as you put the base on  :x  :cry:[/quote]
I'm not sure I understand,
The bottom plate?
-matthias
"It'll never work."
puretube
Quote from: Paul Perry (Frostwave)In my opinion, it is virtually impossible to totally null out the carrier in a passive ring modulator.
You could put a noise gate after it, though.
noise gate before the carrier-input, side-chain controlled by the input signal...
Quote from: puretubenoise gate before the carrier-input, side-chain controlled by the input signal...
Well, of course (slap my bald head) PureTube is right! again. :D
and for guitarhacknoise, yeah, i mean the bottom plate.. dont you just hate it when everything is 'just right'.. until the bottom plate goes on :x  :cry:
guitarhacknoise
paul perry writes:
dont you just hate it when everything is 'just right'.. until the bottom plate goes on.
:D At least I know I'm not alone!
"It'll never work."
toneman
how bout an 8038 for sine/square/sawtooth outputs?
All in one chip!!
What xfmrs are used in the RingerStinger??
1K primary AND secondary??
Was that the the Mouser # refered 2 earlier????
( TL016-0416S )  ?????
I have a jpg of the RingerStinger xfmr&diodes....
No #'s on the xfmrs that i can see.....
afn
staymodulated, cleanly
tone
guitarhacknoise
hey Toneman,
8038 seems like a cool chip, I'll need to look it up.
have no info on the ring stinger trans.
the Mouser # for the trans. I'm using is actually  42TL016 , sorry.
the specs be:
pri imp.=600ct.
sec imp. = 600ct
pri. resistance =65 ohms
sec. resistance = 55 ohms
I wonder if this would be better?
42TL030
pri. imp.=100ct
sec. imp.=100ct.
pri. res.=10.9 ohms
sec. res.=9.1
-matthias
"It'll never work."
Taylor
Quote from: guitarhacknoise
Thanks. Does anybody know where to find the matched diode cases referenced earlier?
Taylor
Quote from: TaylorDoes anybody know where to find the matched diode cases referenced earlier?
So I got some samples of the uc3611 diode array from Texas Instruments. I got 5 in the "N" package, which is an 8-pin DIP, and 5 in the "DW" package, which is a 16-pin DIP (but the package is the same size; the pins are twice as close together). But they both only have four diodes in them; 8 of the pins on the DW don't seem to do anything, according to the datasheet. Is this common? Does it have to do with fitting into a different standard, or do the pins actually do something?
Taylor
So I built this with the TI diode array a while ago and it sounds great. I'm using an old Farfisa organ with a few keys taped down as a carrier, and it's totally quiet when there's no guitar signal going in (actually, I use a bass). I'm not using any boosts or buffers or anything, so I've got a weird, dissonant, ugly effect with a total of 3 components. I'm happy.
I wanted to get some xr8038's for carrier signals, but those guys (Exar) are crazy about samples. I made the mistake of giving them my home phone number and a kind-of-fake company name, and they called me a few times a day for weeks, trying to arrange a time for their reps to come meet me and tour the facility. If anybody with realer credentials would like to help me out, or if anybody knows where I can buy them, please let me know.
toneman
U can get 8038's from Jameco.
at least U used 2.
U could also build a descrete VCO with simultaneous waveforms out.
Did U look at the Mouser site???
these are a common IC function generator.
The 566 VCO is harder to find, but will work OK also.
staymodulated
tone
I found the 8038 a bit annoying. It's a pretty thirsty chip, for those using batteries. And it's difficult to gt a "full" audio range out of it. Midwest Analog had a circuit showing how to get the most out of it (ingeniously overcoming the inherent faults). But Midwest has gone, now.. maybe someone will redraw & post the circuit, if they have it?
I gave up on the 8038 myself, for my commercial ring modulator, and use an OTA as a voltage controlled oscilator, followed by another OTA as a triange to sine shaper. Wider range, and just as good a sine, in my opinion.
toneman
Hey Paul,
that would B the best way IMHO.
i like 2 stay away from "special" chips.
there's always the *famous* 555.
Make it do a triangle, then lowpassfilter it.
Nearly pure sine...
...BTW U need to buffer the tri or the sine 2 drive other stuff.
staynonobsolete
tone
brett
Might mention that CMOS 555s are usually the thing for stompboxes.  555s chew battery power, and can really throw out noise, esp via the power lines.
cheers
Brett Robinson
toneman
*not*  the CMOS 555.
*very* LowPower.
You're still running batteries???
:shock:
Taylor
So I realized that the reason my RM works so well with no boost is that I play an active bass. Indeed, I'm a quick one.
