bsiab components all available from small bear?
Started by liam012, July 22, 2005, 06:56:50 AM
liam012
dont seem to be able to find all the types of caps or values? am i just looking in the wrong place?
transient
You can use "close enough" values for the parts you can't find. For example, the circuit requires a 250pf cap, but smallbear doesn't have that value, so you can use a 220 or 270 pf cap instead of that one. Similarly, i had used a 500pf silver mica cap instead of the 470pf.
Or, simply use two or three components in parallel/series to get the exact value.
emre
