(metal) FX w/ built-in xfrmr: safety-ground or not?
Started by puretube, July 03, 2005, 08:53:26 AM
use 3rd safety-wire? (yellow/green) or not...
Total Members Voted: 24
Voting closed: July 03, 2005, 08:53:26 AM
goosonique
Tried them all .... btw even with the power off (240V here) on the echo unit and having pluged into an amp powered on it still hums!! I find it weird !! The echo not powered and there is still hum on through amp.  :(
<((one man with courage makes a majority))>
Basstyra
I finally grounded my pedal :
The ground wire is screwed between the two parts of the box.
I need a power cable such as for amplifiers or computers, it's big, bulky, but well, it's a need, isn't it ?
The best french bass-related forum : http://forum.onlybass.com
A french DIY forum : http://www.techniguitare.com/forum
My work (stille only in french, sorry ! ) : http://perso.wanadoo.fr/jumping-jack/atelier/atelier.html
puretube
Paul Perry (Frostwave)
Quote from: puretubea great improvement
Good to know you will still be with us for a while yet, Basstyra!  :wink:
Basstyra
H.Manback
Closely related, I want to ask you guys something about electrical isolation with a transformer (in amps in this case).
The way I understand, the old radios which did not use a isolation transformer, and which did not have a safety ground wire, are unsafe because there is a 50/50 chance of the chassis (ground) being directly connected to the phase wire of the outlet. Touch the chassis and you make a closed circuit with the earth, right?
Now when you have a transformer in between the outlet and your power supply, if you were to touch the chassis, it could not make a closed circuit using you (unless you were to touch the other end of the power supply).
The safety ground then only serves as a protection for when for example a filter cap has shorted (still important, don't get me wrong).
Is this understanding correct?
H.Manback
Sorry for the early kick, but I really want to know if I'm thinking on the right track here.
