Passive adder?
Started by Primus, August 06, 2005, 09:16:08 PM
Primus
I want to try something a little strange I read on one of the dub boards. I want to run an AM radio through my pedal board. However, I also want to be able to play my guitar at the same time. I know that you need to use an active device to split a signal to two amps, but what about combining two signals into one pedal? can this be done by just soldering the inputs together (never cross streams, Ray!). I was thinking of having a switch that switched between just guitar and radio + guitar.
Another question, that might be off topic... I was thinking it'd be cool to take the upper stage of a Leslie speaker using an 8 ohm driver and drive it from the cabinet extension on my amp. However, I am concerned that switching the driver load on and off my amp could damage it. Any thoughts?
RandomRedLetters
well there are passive A/B/Y boxes, and in theory you could use it to hook up 2 sources to one amp, its bi-directional. As far being able to mix the 2 signals in the A/B/Y box, im sure you'd need an active one for any signal buffering, boosting, eq etc, basically if you wanted a mixer for the 2 signals.
I would just use a passive A/B/Y box and make sure the level of the AM radio is where you want it before playing.
RandomRedLetters
As far as the Leslie amp thing, dont do it. Guitar amps are made so the load (Speaker cabinet) is constantly on, otherwise you can fry your transformers and/or filtering Caps.
Paul Perry (Frostwave)
Here's a very nice simple mixer:
http://www.aaroncake.net/circuits/mixer1.htm Thanks, Aron!
Otherwise, just hook up the guitar & run the radio in via a 47K resistor to the same point (to avoid loading the pickup). Oh and put a .1uF cap in series wth the 47K resistor, just for luck (& in case there are any bias problems).
