OT: Testin guitar patch cables
Started by John Egerton, August 29, 2005, 10:46:22 AM
John Egerton
hey guys...
due to the complexity of my pedalboard, I've been making my own patch cables.
I was wondering if there was a good way to test these cables (other than using a cable tester) to see if there i any signal degredation within then due to wear and tear and also my bad soldering...
Possibly using a multimeter?
John
Save a cow... Eat a Vegetarian.........
waldo041
http://www.swrsound.com/support/setuptips.php
in the 7th paragraph he explains a quick way to test cables using a nine volt and a speaker. hope this helps. i have used this method for sometime and it does work. you just need a speaker with a 1/4 inch input.
peace,
waldo
scratch
I've made myself a cable tester in a plastic Hammond box, 1/4" mono, 1/4" stereo, RCA and XLR connectors, some LED's and some momentary (NO , Normally Open) push button switches ... very handy. Good for testin for opens and shorts, crossed cabes, etc.
Can't tell if the cable is intermittent with this. I think Craig Anderton a long time ago wrote up a cable tester in GP to detect intermittent cables. I'd have to scan my photocopies and send them somewhere?
Denis,
Nothing witty yet ...
Fret Wire
Besides the tests above for shorts/intermittant, I check cable resistance with the DMM, and capacitance with my cap meter.
Fret Wire
(Keyser Soze)
