Finished...AMZ Overdrive Pro !!!!!!!!!!
Started by petemoore, April 25, 2004, 03:46:21 AM
The Name says it All.
 I spliced a gain recovery stage between the tone/volume pots using  the second half of a dual OA, thanks for the suggestion RDV. I used a 10k trimpot before the GR stage, just in case, doesn't do much and isn't necessary.
 I ran out of 1 megs, but used a 400k...[ala dyna preamp], I'll probably just solder values of fixed resistors to it's ears 'till it gets well past both ends of the range I might use...below unity/well above unity.
 I like the many ways it works.  Quite a powerful pedal. A BC109 for Q1...[if you like BC's in gain stage, I do], I tried a 2n2222, and that changed the character too.
 Thanks to Jack Orman at AMZ, this is going to be very nice pedal to have around.
 Gobs of gain, Plenty of power in reserve, highly variable Overdrive sounds...Overdrive Pro!
RDV
stumper1
Looking for some (lots) of help with this.  Built the Overdrive Pro and really dig it so far.  Tried LED's and the output was fine.  Swapped out for diodes and the decay of the signal sounds much better but output is lacking.  Used the layout at Tonepad (thanks) to make the PCB.
Can anyone help with basic (very) step by step instructions for the Gain Recovery stage?
Thanks,
Deric
Deric®
bass_econo
Quote from: petemooreI tried a 2n2222, and that changed the character too.
Pete how much difference did the 2N2222 make?  It seems to be unliked in most circuits.
RDV
Quote from: stumper1Can anyone help with basic (very) step by step instructions for the Gain Recovery stage?
RDV
stumper1
RDV -
Thanks!!!  That's just what I'm looking for.  I do have a couple of questions.  Looking at the schematic, the GR stage is fed from the middle lug of the Mid control.  I use pins 1,2 and 3 of the Opamp for the GR stage and then replace the existing 1M Vol pot with a 100k.  Is this correct?
Also, I can see that I need to cut the traces on the board between pins 1-2 and between pins 3-4.  From there I am not sure of which pins are the B,C,E in your schematic.
Thanks for the help! :oops:
Deric®
Doug_H
Quote from: bass_econo
Huh?!? :?:
Doug
RDV
Quote from: stumper1RDV -
Maybe this is more what you're looking for then.
RDV
bass_econo
Quote from: Doug_H
Huh?!? :?:
Doug
It seems that whenever the 2N2222 is brought up everyone talks about how terrible it is and Pete said he tried one and it had it's own character.  I guess I was asking for an elaboration on the character.
stumper1
QuoteMaybe this is more what you're looking for then.
EXACTLY!!!!
Thanks!! 8)
Deric®
aron
Doug_H
Quote from: aronI love the metal can 2N2222!
Me too!
Doug
WGTP
Try an LED/SI diode combo and maybe you won't need the recovery stage.   8)
Stomping Out Sparks & Flames
RDV
Quote from: WGTPTry an LED/SI diode combo and maybe you won't need the recovery stage.   8)
Howzabout both? :twisted:  :twisted:
RDV
WGTP
Now that I think, the Rat I rebuilt had 4 SI's, 2 going each direction.
Many possible combination that would result in higher clipping threshold than 2 SI's and lower than 2 LED's.   8)
stumper1
I tried 2 LED's, 2 diodes, 1 LED/1 diode.  Of those so far I liked the 2 diodes the best.  I didn't try any other combos yet.
Thanks for the tips.  I'll definately give it a try!!!
Deric®
