Biasing transistors or JFETS . . .
Started by msb69, September 20, 2005, 04:54:04 PM
msb69
Will this have any effect on how bright or bassy a pedal is overall?
I've got a pedal with bias pots for each transistor.  Will adjusting these allow me to voice the pedal a certain way?
formerMember1
QuoteWill this have any effect on how bright or bassy a pedal is overall?
Yes.  But other parts make up the tone too.  Capacitors control alot of the tone also. :wink:
Try searching the forum for a better answer.  There is a real lot of info about biasing transistors on this forum.   :wink:
What pedal is it?
davebungo
The answer to this question simply put is that it could well do and feel free to try - just remember where the trims were before you disturb them.
The normal purpose of trim adjustment, however, is not to "voice" an effect but to adjust a circuit in order to compensate for uncertain device parameters.  If all device parameters were known in advance there wouldn't be many trimpots in effects.  Usually a trim will adjust the DC operating point (or bias) of a part of a circuit to allow the signal to swing up and down in a fairly symmetrical manner (excluding effects which depend on asymmetry).  Trims could do all sorts of things - it is best to find out before you tweak if you are unsure.
