Jordan Bosstone Build Report (Pics Added 8/1/06)
Started by Paul Marossy, July 30, 2006, 07:47:22 PM
Paul Marossy
Thanks for the compliments all. Ever since I did my first airbrush job on an armor model around six weeks ago, I just had to try out something similar on a stompbox. I think I'll use my airbrush on the next build for a sunburst finish and see how that goes...  :icon_cool:
Yun
ah, the great boss-tone,  with stock values; mines didn't have ANY sustain at all,  So- here's the mods from my notes:
-High gain transistors (MPS's)
-18K is changed to 22K
-Ommit the 470pf cap
-add tone control (big-muff)
-Add Compression control (AMZ)
Those were a few that REALLY made a change in the tone/sound of this particular fuzz.  The results were actually quite cool.  It was really touch-sensative and had A LOT of feel to it, sustained better than a Big-Muff, etc.
Pretty cool little circuit, definateley one of my faveorites....
"It's Better to live a lie, and forget the past, then to Forget a lie, and live the past"
Paul Marossy
Quotewith stock values; mines didn't have ANY sustain at all
Mine actually sustains pretty nicely. Must the combination of transistors that I have, I guess.
QuoteIt was really touch-sensative and had A LOT of feel to it, sustained better than a Big-Muff, etc.
Mine is really touch sensitive as is. In fact, I think it's the most touch sensitive of all the pedals that I own... go figure.  :icon_cool:
Stock, it's quite nice.  Following up on some comments Aron made maybe two versions of this forum ago (  :icon_lol: ), I increased the input cap value, or rather made a second cap switchable.  Increasing the input capacitor value has an interesting effect.  It fattens it up a bit but it also has the strange quirk of producing what sound like octave-down undertones for some notes.  Not exactly an obvious octave-down box, but certainly a different flavour of fuzz and quite fun.
I don't think there is any magical cap value, but it makes sense that significant changes to input bandwidth wouldn't occur with anything smaller than something around 3-4 times the original value.  That might say .02uf on the schem but obviously it will be .022uf in standard values, so switching to a .1uf cap (or greater), or simply tacking on .068uf or more in parallel, should be fine.
Since I don't have multiple channels with individual EQ on my amp, I like to set it for bright clean tones, which kind of obligates something to tame the fizz on distortion pedals.  here, I just used a cap in parallel with the clipping diodes, similar to the Dist+.  I have a 3-position slide switch on mine, with stock, treble cut, or bass boost being the three settings.
hilbi
hilbi
Built so far: PNP FuzzFace, MXR Dynacomp, EA Tremolo, AMZ Mosfet Boost, AMZ Super Buffer, Blue Magic, Peppermill, RM Axis Face, Sparkle Boost, BSIABII, ROG Ruby, AMZ Mini Booster, MXR Phase 45 Univibe, Tremulus Lune, Dallas Rangemaster, Ross Comp
Paul Marossy
I don't know about sound samples, but I can get some of that early Al Di Meola tone at a certain setting. What a fun little box!  :icon_cool:
Yun
Quote from: Paul Marossy on August 04, 2006, 12:08:27 AM
Hmmmmm, now that i look back on it, i was using a Marshall stack.  As all of youse guys know- Marshalls and clipping devices (FUZZ, DIST, and OD pedals) do not mix well.
Compared to the stock pedal, and the "yunified" pedal, i MUCH prefer the yunified one.
Paul Marossy
QuoteCompared to the stock pedal, and the "yunified" pedal, i MUCH prefer the yunified one.
That's the cool thing about DIY - you can tweak things to your heart's content.  :icon_cool:
Yun
Quote from: Paul Marossy on August 05, 2006, 12:44:53 AM
Right on, my friend  :icon_wink:
Paul Marossy
oldrocker
OK.  I just breadboarded this one and as much as I try to fight making another distortion box this is a great sounding pedal.  I like how it doesn't over fuzz the single note high strings too much and then when you hit a power chord it kills.  Some other fuzz pedals I've made fuzz out the high lead notes a little too much sometimes when I just need a light distortion on those notes.  Yet when playing double note bar chords I want that high power crunch.  The Bosstone gives me both and the sustain is fantastic.  My wife heard me playing through the breadboard and yelled "Oh no!  Not another fuzz box!!"  But I just have to box this one up.  She just doesn't understand.  I hope this doesn't put my marraige on the rocks. LOL! ::)
Paul Marossy
Quoteas much as I try to fight making another distortion box this is a great sounding pedal.
For me, the quest for the perfect distortion box is never ending. But, I think the Boss Tone is one of those pedals that makes it seem possible that the perfect distortion box is acheivable!  :icon_wink:
oldrocker
The quest for the best sounding distortion box is impossible.  There are so many different variations and tweeks that I have to have a large enough arsenal just so I don't leave anything out.  It's nice to find one I haven't built yet that doesn't sound like any of my other ones.  Aagh!!  Will it ever come to an end?  (I hope not.)
Gilles C
Quote from: Paul Marossy on August 02, 2006, 10:21:00 AM
A box from the past, still waiting for the perfect circuit. (could be a Fetzer Valve V2... Sunburst = Fender = Fetzer)
http://gtechblues.com/SunburstMaking.html
Gilles
Paul Marossy
QuoteThe quest for the best sounding distortion box is impossible.
I know, it's too subjective. But for a circuit that sounds good and is very sensitive to picking dynamics, etc., the Boss Tone as I have built it sounds excellent.
QuoteA box from the past, still waiting for the perfect circuit.
I remember that sunburst finish enclosure. I hope a circuit can find a home in it some day!  :icon_cool:
Phorhas
Yeah, I saw that one in my Silicon/hybrid fuzz escapades :)
Breadboarded it - sounds preatty cool... but the bender is too "contained" for my taste :)
Electron Pusher
brett
Hi
a couple of years back I built a couple of these - one with a muff tone section and one with 2 x single-pole filters that rolled off at about 7 kHz.  Looking back, a problem with these was that they increased the output impedance.
Knowing what I now know, if I was trying to control high-end buzz, I'd use 2 filters consisting of (a 1k resistor in-line and a 0.022uF cap to ground).
QuoteAs all of youse guys know- Marshalls and clipping devices (FUZZ, DIST, and OD pedals) do not mix well.
Hmmm.... There are Marshalls and Marshalls.  Maybe JCM900s don't respond (they are one-trick ponies, really) but my 18W and the clean channel of my JTM60 both respond really well to fuzz and distortion pedals.  Tubescreamer, bluesbreaker, fuzzface, fuzzrite, bosstone, tube-sound fuzz to name a few.  Next on the list is a Maestro MFZ.
cheers
Brett Robinson
