EZ Vibe turns into Tremolo
Started by petemoore, September 29, 2005, 05:18:00 PM
  Everything looks good, the phase stages pass signal [when there is light on the LDR's, phasing is more tremolo like today though, I wonder if anyone has an *Idea what could cause this...it goes to about 0 volume with the LDR's under dark conditions, depth is 'minimal' at all setttings... :icon_confused:
MartyB
Pete The Easyvibe does have a plain vibrato setting.  Is that what you're hearing?
  Not what I'm hearing 'now'.
  I was hearing the sound of an 'offoobeat' tremolo, caused by...one of the wires to the light section...a 'blind' find...I'm inclined to be just happy that it's 'twisted' just right to work..one of those bend it this way is bad, bend it the other way it's worse [serious blap] bend it just so and it's 'good', I found a bend 'place' that seems to be able to withstand fairly hard knocks, and I sure don't want to have to tear down the whole thing just for the satisfaction of actually finding "it"....as long as It' isn't a bother I will leave well enough alone.
  This Vibes very wobbly to less wobbly is truly superb, thickness of lushness factor quite good also...it's WORKING !!! does subtle phasing too, but the attractiveness of the wobble is strong .
  Whew it had me beat there for a time.
