Ruby Amp (ROG) ... complete! ... but very faint?
Started by Aurin, October 21, 2005, 11:53:57 AM
Aurin
I built a ruby with fetzer valve mod [ http://www.runoffgroove.com/fetzer-ruby.png ] and was quite pleased to find, when I had finished the last joint, that it worked. However it was VERY faint.... And the gain pot seemed to work backwards. (turning it clockwise turned the volume DOWN).
So I re-wired the pot and that seemed to help quite a lot. But it's still not very loud at all (barely above the volume of my electric's sound [without it being plugged in to anything]) . That's with the volume and gain pots turned ALL the way up.
So perhaps I'm reading something wrong on the schematic?
I figure I might've mis-wired the volume pot and possible the trimpot ... When I turn the trimpot full clockwise it totally kills the sound -- only at 1/2 rotation or less do I get any sound .
This is how I've got things setup (As I understand pots in schematics) :
Is that right?
If you have pictures of the underside of a working fetzer valve or ruby w/ fetzer valve that would be awesome....
vanhansen
Go from Pin 1 of the LM386 to lug 3 of the gain pot, then to lug 2.  Lug 1 goes to pin 8.
On the volume pot, come from the 22n cap of the Fetzer Valve to lug 3.  Lug 2 goes to pin 2 of the LM386.  Lug 1 to ground.
Yes, your diagram is correct.  You've got the pot lug order correct.
Erik
Aurin
Thanks for replying  =) Volume pot is wired correctly then....
I'll have to double check the gain pot when I get home... (After all I did end up switching things around a bit with that).
It could of course be the cruddy lil' speaker I'm using.... 4 Ohm 2.5 W 4" oval speaker that was harvested from an old TV (and I do mean old, didn't go above channel 13! heh heh).
Steben
A speaker with sensitivity of 100dB@Watt sounds double as loud as a speaker with 95dB@Watt. For example: My HiFi speakers (Wharfedale, not the worst around !) have 86dB@Watt !!! They sound 2x to 3x as quiet with the same input as a 100dB speaker!
smashinator
Is your speaker in a box?  If not, it will be much much softer because (if I remember this correctly) it phase cancels itself.
People who say it cannot be done should not interrupt those who are doing it. - George Bernard Shaw
http://pizzacrusade.blogspot.com/
Aurin
Erm... no, no it isn't... I can't say as I've heard such a thing.... Guess I'll box it up and see!  Thanks for the suggestion.
I really want to get this thing rockin'
I'll also probably add a transfer jack so I can use the internal speaker or use it as just a head... Huzah for switchcraft's 13A =D .
Aurin
Stephen,
Ack! Don't know how I missed your post but... Good info =)  I hadn't even though of the dB sensitivity of the speaker.... Is there any "easy" way to guesstimate that value? Or would I need fancy equipment to make that calculation?
I really should try hooking up a real guitar speaker ...
spudulike
Aurin
I'm using an MPF 102 from small bear -- should be Gate, Source, Drain   when looking at the rounded part .... If I mixed up the source and drain connections I'll have to resolder a bit heh.... hopefully that's -not- the issue... We shall see, I suppose.
Thanks for the suggestion =).
Connoisseur of Distortion
with sensitivity, i am fairly sure that a 3 dB increase is perceived as a doubling in volume... but snesitivity can make or break your cab, yes
Aurin
Everything checks out --- it IS louder in a box rather than with the speaker on my work table.... Who knew? heh... When I put it in it's permanent home I'll have to take pictures... thanks for the suggestions all =).
