I inherited a bunch of "vintage" components...are any useful for effects?
Started by Noplasticrobots, October 20, 2005, 07:43:04 PM
Noplasticrobots
My electrician/pack rat of a grandpa finally decided to give up some of his electrical components. I figured some might be of use for effects building, but I'm not too sure. Based on the packaging, I'm guessing almost all these parts were made in the late 60's to mid 70's. If anyone can tell me what's useful for effects making I'd be much appreciative.
A few enevelopes of diodes:
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0517.jpg
Transistors:
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0510.jpg
Component potpurri:
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0506.jpg
A couple of output transformers; a D-I T55 and a 2F555
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0503.jpg
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0505.jpg
Some transistors and either a diode or some odd resistor. Note that the diode/resistor has a yellow "H" marked on it. On the back of the blue paper it says that they are rated for 1000VDCW and have a ±%10.
http://i13.photobucket.com/albums/a278/Noplasticrobots/IMGA0494.jpg
I was told that most of these components came from a TV repair shop. Later tonight I'll be sorting through some ICs and a bunch of old ceramic disc caps and I'll post them later.
I love the smell of solder in the morning.
nelson
CLM3006 40 mA, photomod six volt module in 4-pin - package. Operational temperature range from -25°C to 75°C.
My project site
Winner of Mar 2009 FX-X
Arn C.
Here is some more info for you:
2n169= SK3861  NPN Germanium Transitor
2n147=   "           "           "              "
2n1308=   "         "           "              "
2n412=  SK126A  PNP  Germanium Transistor
ECG2086 =  If this is an IC, it is a Darlington Array PNP Germanium(4-unit)
Thats all I have for you!
Arn C.
Steben
Hmm, Darlington germanium PNP array... drool... (this is a Homer DIY quote)
Arn C.
There are also 5, 6, and 7 stage darlington transistor arrays available from NTE
NTE2085 4 stage
NTE2086    "
NTE2078 5 stage
NTE2084    "
NTE2082 6 stage
NTE2083    "
NTE2079 7 stage
Also:
NTE2087 & NTE2088 4 stage with predriver stage
Arn C.
Hal
looks like you have mostly logic ICs there...anything starting with 40 is ususally CMOS logic, and anything with 74 is TTL logic.
the transistors look like a score, though.  a simple google search for the part number will ususally tell you if they're Ge, Si...high/low gain...those are the only really important stompbox characteristics :-D.  That and tone.
