pcb layout for a mounted 6 pole rotary switch
Started by powerplayj, October 30, 2005, 09:22:50 AM
powerplayj
Where could I find a pcb layout for a 6 pole rotary switch (mounted) to be used for cap switching?  I have already populated my wah pcb using a Tonepad layout.  Had I decided on using a rotary switch beforehand I would have probably used one of JD's boards which has all the sweep caps on the wah pcb.   A layout like Stuart Castledine's (below) would be ideal.  In the meantime, I'll try my hand with whatever free pcb software I can find.
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
jimbob
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
spudulike
powerplayj
You guys are awesome!!!  Would it be advisable to use the ground and resistors or could I omit the ground and jumper the resistors?  I assume they would help keep the switch from popping but is there any other reason for their use?
Last question....should the ground lead be connected to a jack, wah shell or pcb ground?
next build(s): ???
