Got some Tube transformers, what amp to build?
Started by nelson, October 28, 2005, 04:10:21 PM
nelson
I managed to get my hands on a 40W output transformer for 2X6L6 and a mains transformer with 350VAC + 6.3VAC.
Now, what amp should I build?
I am Thinking about a Vibrolux Reverb.
I understand this is a DIY stompbox forum, however I hate the board style over at the amp forums...needs a serious overhaul....and less spam.....
Also, I am having trouble finding a suitable aluminium chassis, I mean the Vibrolux has ( tubes and 4 transformers/choke) Chassis needs to be large...Every place sells them predrilled for $100 plus....not quite what I had in mind paying for sheet aluminum....
all ideas suggestions welcome....
My project site
Winner of Mar 2009 FX-X
jrc4558
Hey Nelson!
I suggest you build something like this:
This peramp and phase inverter http://www.blueguitar.org/new/schem/trainwreck/wrek_pr.pdf
with a generic 5881 or 6L6 class AB1 output stage.
I tried it with a quartet of EL84s in class AB1 and its a killer.
I mean you will obviously have to tweak the voltages and reduce some gain here and there, but should be ok.
Paul Marossy
Build an Octal Madness! I'm really considering building this one myself in the near future.
Peter Snow
Hey Paul (& others),
I was just looking at the schem for the Octal Madness and I noticed that the speaker jack connected to the output transformer was a "shorting" type.  That is, with no plug (connected to the speaker) inserted, the output windings of the trasnsformer are shorted to ground.  Would this not destroy the transformer in pretty short order?  :icon_cry:   I guess the best solution is to have a load of the correct impedance connected, but for those times when you forget... I always thought that an open circuit was better than a short circuit in this situation.  Is there some other reason for the shorting jack?  ???
Cheers,
Peter
Remember - A closed mouth gathers no foot.
Paul Marossy
QuoteI was just looking at the schem for the Octal Madness and I noticed that the speaker jack connected to the output transformer was a "shorting" type.  That is, with no plug (connected to the speaker) inserted, the output windings of the trasnsformer are shorted to ground.
I wonder about that myself. The designer of the circuit, David Jones, must have done it for a reason.
