I love the ROG Tonemender
Started by audioguy, October 31, 2005, 11:42:11 AM
audioguy
Totally killer pedal! I've had a bunch of issues getting it up and running, but I got them all ironed out and I really like this unit!
One quick question- when I use the switch to shift the mids I get a pop- but only if I havnt used the switch in a few minutes. If I toggle back and forth its silent, but if I play on one setting for a few and then switch it pops. Any quick fix?
stm
Try placing a 1 Mohm or higher resistor across each switch half (i.e. one resistor in parallel with the 220p, and another in parallel with the 33n cap). This should fix or at least attenuate the pops.
Let us know if it does the job!
audioguy
OK- I'll give it a shot and let you know what happens!
Thanks for all of your help!
Audioguy
audioguy
I put a 1M in parallel with C7 and tested it out- problem solved!!
thanks for a great unit!
