Gonna try another Rangemaster
Started by SG Lou, March 30, 2006, 02:00:41 AM
SG Lou
I got a few extra parts lying around ( Mullard OC44 PNP's )from 2 other builds and i'd like to try this one out and see how it sounds.
http://aronnelson.com/gallery/album18/DALLAS_RANGEMASTER
Where can i get the board and what kind should i buy?
Would this one work?
http://www.diystompboxes.com/cart/stripboard1.jpg
Also, Correct me if i'm wrong but is this the parts list ?
1 - 470k  Resistor
1 - 68k  Resistor
1 - 3.9k  Resistor
2 - 50uf  Electrolytic Radial Capacitors
1 - .005uf  Ceramic Capacitor
1 - .01uf  Ceramic Capacitor
The switch, pot and jacks i have.
Thanks for your help,
...Lou
Bron-Y-Aur-Stomp
* use 1% metal-film resistors (less hissy)
* input cap of .033uF or .05uF seem to work well for single coils, around .005uF and .001uF for humbuckers (make it switchable)
* 70-95 gain is sound pretty cool.
resorces:  http://www.geofex.com/Article_Folders/Rangemaster/atboost.pdf
                http://fuzzcentral.tripod.com/rangemaster.html
good luck!
Peter Davidoff
Hi,
I do not like ceramic caps! Better use film!They give smoother sound!
Replase 68k resistot with 100k trim pot(wired as a wariable resistor) and adjust Colector voltage around 7,0 V!
Good luck!
Peter
  IF you're using a stripboard layout that llooks like the stuff to use.
