pot orientation question
Started by 440hz, January 21, 2006, 05:56:32 AM
440hz
I was going to ask the author about this but thought maybe it apllies to all vero board layouts.
My question is does it matter which way I wire the pots, I can't tell if they are shown shaft
facing you or shaft facing down in the layout in the link. Would it make any difference?
http://aronnelson.com/gallery/album17/SCRAMBLER
I wired mine as though the shaft was pointing down so we are looking at the back of
the pots and it seems to work OK.
tiges_ tendres
if the pot works in the wrong direction, then change the outer two wires.
I probed a pedal for hours once, pulling components and testing until i realised that the pot was wired backwards meaning that cranked up was actually cranked down!
Try a little tenderness.
littlegreiger
Quote from: 440hz on January 21, 2006, 05:56:32 AM
I think you got it the right way. Looking at the layout that's the way that looks right to me.
