jumper between transistor sockets easy face?
Started by janus, January 22, 2006, 03:04:33 PM
janus
Hello,
I'm building the easyface and having trouble figuring out the connection from the Collector of Q1 to the Base of Q2. I'm using sockets and was wondering if it is common practice to use a small jumper wire to connect them and then conect the 33k resistor to the jumper. Or if you wrap the wire of the resistor around the socket plugs to make the connection. It seems to be my problem as far as where the circuit dies. In my previous attempts Q1 has no reading, so I have decided to start from scratch again and realized that was a question I had.Any help is appreciated
thanks
brian
janus
anyone? sorry to bump..just having trouble.
thanks,
Brian
