larsen with geofex millenium box
Started by domenico, January 25, 2006, 09:29:02 AM
domenico
when I bypass a boss sd1(drive and level past the half) or a big muff with this loop box it works but I hear some strange squeals , what's happening ?
when not bypassed the box works well (no squeals)
thanks
domenico
domenico
d95err
Quote from: domenico on January 25, 2006, 09:29:02 AM
thanks
domenico
What other effects/amps are you using, and in what order? Do you get the same problem if you disconnect the SD1 completely?
When using the regular SD1 bypass, the signal is buffered. You could have some kind of problem (RF-interference, oscillation, ...) which the buffer helps preventing. When you true bypass the SD1, the buffer is gone, so the problem appears. I suppose the same goes for the Big Muff.
domenico
guitar>millenium loop box with sd1 or big muff > amp ,  nothing else
no I don't
so what should I do ?
thanks !
