Looking for 100 hFE Si transistors
Started by warioblast, February 03, 2006, 09:15:37 PM
warioblast
Hi,
What Si transistors (NPN & PNP) are more likely to be 100 hFE ?
Cheers,
Fabrice
  That's funny, me too. I rebuilt a FF that was 'tore down' missing this and that, to Axis Face 3 specs...couldn't find the other 2369's ahkk...sounds Roughk  ??? I know that it'll rock when I get the right gain compliments in there 8).
  I think you want to try some 2n2369's, or NTE123/[too bad there isn't reverse crossref on the NTE site...HA], 2n4401's sometimes measure low like that...uh...
  You could take a look at piggybacking 2 higher gain Q's and tuning them to a lower Hfe...where is that...could be Marcos Munky has a Rangepig you could look at.
  I did a Darlingpig schematic, a redraw of that might be there...for use with a lower than optimal gain Ge for Rangemaster type thang. Thing to remember on that one, if the leakage is high that noise is then amplified.
MartyB
2N2222's will get you in the ballpark.
bioroids
2N3904 are pretty low gain. Also BC549A have a minimun of 110 on the datasheet (same 547A and 548A be sure the sufix is 'A' as that indicates the Hfe range)
The real Hfe will vary from the datasheet, so if you want exact 100 you will have to buy a bunch and measure them. The measure should be made at the collector current  you will use, as the gain varies according that.
Luck!
Miguel
Eramos tan pobres!
mac
MPSA42
I bought 10 and they are all about hfe=100.
Also try 2N2219.
mac
warioblast
bioroids
If you can go with the DMM to the electronic shop and try to measure before you buy ;)
Eramos tan pobres!
Dragonfly
just about every 2n3903 ive tested (i have about 350 of 'em !) has been in the 100-125 hfe range....the 2n3904's tend to be a bit higher, and the 2n2369's a bit lower, at least in my experience....
AC
Speeddemon
Quote from: bioroids on February 04, 2006, 07:33:15 AM
All the 2N3904's that I've used were 240+!
2N2369's and BD-135-10's; those hover around hFE 100. (note the 10-suffix of the BD-135. There's also the BD-135-16, which is higher gain)
The 2N2369 has become one of my favourite Si trannies, for Fuzz Face-ish circuits.
I also have 2N3114's, quite a bit bigger, but lower hFE's. Around 55-85.
Meanwhile @ TGP:
"I was especially put off by the religious banterings written inside the LDO pedal. I guess he felt it was necessary to thank God that someone payed $389 for his tubescreamer!"
Paul Perry (Frostwave)
I just had a bit of trouble, because some 100 or so Hfe 3904s got mixed with some 250 Hfe ones.... the circuit didn't call for precise matching, but 2.5 to 1 was a bit far..... generally, the lots from particular batches were fairly close to each other. I shouldn't have consolidted what was left :icon_mad:
MartyMart
I vote for 2N2369's, great for Q1 in an Si "FF"  :D
2N3903  ? ...... I've never had any .. :icon_wink:
MM
Speeddemon
Quote from: MartyMart on February 07, 2006, 08:47:26 AM
Try a 2n3114 (hFE around75-85) for Q1 and a 2N2369 (hFE around 105-115) for Q2! Ideal hFE's for the typical Ge trannies in a FF circuit,
and with some 47pF or 100pF caps from C to B, it sounds rather Ge-ish too.  ;)
Meanwhile @ TGP:
