Maxon OD-808 for OD-820 what the one changed?
Started by ANDYEFFECT, February 15, 2006, 06:37:22 AM
ANDYEFFECT
What did change among the two pedals? which the differences?
is it just the placement of a circuit to increase the voltage it interns from 9v to 18v?
abraços
hugh
André
ANDYEFFECT
Quote from: ANDYEFFECT on February 15, 2006, 06:37:22 AM
abraços
hugh
André
maxon uses two 1458 op-amp?
JHS
The OD-820 is a stock TS-808 with Chargepump and a slightly different gain adjustment (double pot - FB-Loop and RC-network alà Dist+).
Furthermore there is a passiv mid-filter with a recovery stage after the clip-stage.
JHS
ANDYEFFECT
Quote from: JHS on February 15, 2006, 06:24:10 PM
JHS
is there some way of transforming the od-808 in od-820?
JHS
Short answer: IMHO No !!!
Of cause you can mod the 808 to 820 specs, but afterwards you might be disappointed with the sound.
Compared to the 808 the 820 is a thin, artificial sounding OD with only a bit more headroom (the I-buffer in the 820 operates only with 9V) and a little more output. IMHO the 820 can't beat a good 808.
You can change the ICs in the 808 to LF 353, JRC TL072 or OPA 2132 for a clearer, less middy sound.
JHS
