Millenium bypass problem
Started by nunocaldeira, February 19, 2006, 09:27:56 PM
nunocaldeira
Hi all,
I saw a web site talking about the Millenium bypass that shows a perfboard configuration for the millenium 2.
Thay say that the low leakage diode actually brings more problems than properly advantages.
It´s writen in spanish but here it is.
http://www.pisotones.com/Articulos/truebp.htm
The problem is: I built the board without the low leakage diode. BUT The led is allways turned on.
I am using it with a DOD 250 clone.. does the output pot makes the place of a pulldown resistor? I tried to put the resistor there (without soldering, just holding it) and it didn´t work...
Thanks in advance,
Nuno Caldeira
bioroids
Check the pinout of the transistor and the connections. The circuit works perfect if done properly. I never had a problem using the low leakage diode.
About the volume pot, if it is after the last capacitor then it acts as a pull down resistor too, you dont need to add one.
Luck
Miguel
Eramos tan pobres!
nunocaldeira
Thank you Miguel,
I thing I have a dead FET. I tried everything and it´s the same. Too late to get some bs170's at a store, they´re all closed now. I´ll buy some tomorow and check again.
Nuno Caldeira
bancika
dont waste time with millenium, 3PDT switches are not expensive and make life easier :)
nunocaldeira
The thing is I can´t get 3DPT at reasonable prices in Portugal :(
Thanks anyway
bancika
try www.banzaieffects.com
I'm from Serbia and I ordered some stuff (and 3pDT's) from them. Great prices and service
nunocaldeira
wow...
Just spent some money there...
Nice prices!
Thank you VERY MUCH !
Nuno Caldeira
(I'm gonna throw away my "mallfuntion bypass 2")
Peppe
Thanx for the banzaieffects link, almost everything is about 50-70% cheaper than here in Finland...
